Re: Refitting tub to Siemens WM5020
Penguin45 wrote:If you use the coil part of the spring as the leverage point, they will pop back quite easily.
Next time, take the front off – it’ll save you pulling the tank.
Thanks for this, I’ll give it a try. I did actually take the front off as well but it was still very fiddly. I needed to remove the tub completely from the chassis as it was much easier to clean it on the bench rather than in situ.
