Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › Refrigeration gear?
- This topic has 5 replies, 6 voices, and was last updated 15 years, 11 months ago by
whiskeyjack6058.
May 13, 2010 at 9:26 pm #54600
whiskeyjack6058
ParticipantIm getting into system work, did my first re-gas the other day and need to get kitted out for work with r600a and possibly r134.
Looking on connect the price of the lokrings are a bit silly especially when it shows the compression tool to fit them.
Anybody know the best place to shop for the gear, looking for a charging station with built in vacuum unit, need the lot. A manufacturer who I do work for is pricing it up at cost for me but wanting to see for myself because they will only pay for what I require for their jobs (which if fair enough!).
Thanks in advance.
Rob.May 13, 2010 at 10:28 pm #320272burns
ParticipantRe: Refrigeration gear?
Hi contact Pete Chitson of Vulkan Industries who supply lokring and all other equipment. Not used his number for a while but it was 077672258504. Bought most of the equipment for Maytag from him. Very obliging and will go through it all and train you in its use if required and of course you buy over a grands worth 😆
May 13, 2010 at 11:46 pm #320273kwatt
KeymasterRe: Refrigeration gear?
Hi Rob,
Talk to Ian Dales and Bryan Williams, both old fridge hands and both will, probably, tell you what I will here…
Refrigeration really isn’t that hard, once you get your head around it. At least so long as all you want to do is fix it when it breaks.
But what I and many others would suggest is to steer clear of Lockring. It’s expensive, prone to failure and an absolute b1tch of a thing to get right in the field. Personally, I’d never use them unless there was no other options available.
A good microflame and a bit of experience and you’re sorted. No buying stupidly expensive Lockrings.
However, to each their own as they say. I just don’t like the things, could never get the damnable stupid system to work properly so, gave up. Life’s too short.
Brazing works.
And, I can fix ten or more fridges easily with flux and brazing rods for the cost of a set of Lockrings to do one the last time I looked.
I’d steer clear of 134a unless you are qualified and have FGAS. Not that anyone’s ever liable to bother you about it but, it’s a hassle that’s being lessened by the day and, all R134a units will be banned from production next year IIRC so, a bit pointless in many ways.
Let me put it this way, once the FGAS interim certificate expires (kindly provided by the WTA for buttons) we won’t be touching any CFC gas as it’ll then be either commercially prohibitive or just plain outlawed.
HRP aren’t bad for kit, not the cheapest but they do stock or can get quickly a huge range of stuff from refrigeration work and they do tend to sell decent stuff too. There’s branches all over the place as well as online ordering…
http://www.fridgenius.co.uk/hrp.htm
HTH
December 4, 2010 at 11:02 pm #320274Allsorts
Now here is where I start to sound totally thick…
R600A .. I gather this is the refrigerant that is safe for anyone to do… ie. non-CFC .. Safe for the enviroment. Is this correct?
If this is correct… Can anyone point a thck od goat that wishes to learn a bit about it in the right direction .. and that doesn’t mean to a supplier website… because I wouldn’t know what I would be looking for…
Now I know a lot of you have little time to spare.. just like me… but if you could illuminate a direction, or even acknowledge the request for info and come back to it later when you’re not so busy, it would be much appreciated.
George
December 5, 2010 at 12:20 pm #320275eastlmark
ModeratorRe: Refrigeration gear?
Disagree about the lockrings…… never ever had one fail or leak and fitted, literaly 1000’s. Way quicker than Brazing and less equipment to lug around. (you do need good eyesight though the read the sizes!) Qualtex currently cheapest supplier. The only rip off is the driers with tails on and if anyone can point me the way of a cheaper alternative…..
TrySRW for equipment although you will find most refirgeration suppliers are geared up for commercial work and have little domestic stuff.
R600A is now the most common refrigerent for domestic stuff and is basicly a hydrocarbon like Butane. Yes it is flamable under certain circumstances so you need to know what you are doing, but its a great gas to work with as you do not need to recover the old stuff and you are dealing with much smaller quantities then the older systems used.December 5, 2010 at 1:49 pm #320276admin
Hi Whiskey
If your starting out and very short of money then a good secondhand vac pump would do you with a standard set of gauges and change one of th dials to a R600A – 1bar dial.I have a couple of lockring crimping units that are sitting round gathering dust as the same with the charging scales ect.
I personnelly braze all my refrigeration,Cost of brazing is less than £1 per compressor plus refrigerant + drier.we change a compressor within 45 mins from start to finish.
e-mail me of what you need.
Bryan
