Refrigeration Leak Dye
Home Forums General Trade Forum Refrigeration Leak Dye
  • #73602
    madangler1
    Hi guys, does anyone use a dye for leak testing on a domestic unit, was with a customer that does Ac on cars and he was telling me they use a UV dye to pin point the location of the leaks.
    I don’t know can this be used was R600?
    Just one of those random thoughts.
    #388121
    Dales-Electronic
    Re: Refrigeration Leak Dye
    No – for no other reason than the amount that you get for sundries would not cover the cost of using the dye together with capital expense of getting the injector/uv lamp. With a/c most of the pipework is visible with domestic very little is.
