Regassing tumble dryers
  • #16941
    whitevanman
    Is this a rumour or myth, I have heard that Electolux group now manufacture a tumble dryer which uses no heater but a compressor and uses a small system similar to air conditioning unit.
    Is it me or is the world going mad 🙄
    confused
    Wayne
    #172263
    funkyboogy
    Re: Regassing tumble dryers
    yes you are right mate
    …the part about being mad that is….
    #172264
    litlor
    The next thing they will be using gas
    #172265
    Alex
    Here it is the T59800 Dryer. Product code 916-012-130 To be found at http://www.aeg-electrolux.co.uk/node146.asp?ProdID=3743
    Sorry my picture is a bit small
    #172266
    Interesting…. runs on R134A as well, how did they manage that?
    #172267
    whitevanman
    Thanks for restoring my sanity, had a look at http://www.procorner
    Compressor PART NO 112 54 20-00/8
    @ 259,07euro £173,58 looks an expensive repair
    funkyboogy dont think you will need a compressor where u live , just leave it outside.
    Wayne
    #172268
    Just got a call about one of these making a clunking noise. Checked up here first and used Alex’s link to look it up on Lux site. I was so glad to find that the manufacturers give a free 5 year guarantee on this product. :duck: Rang customer and advised her to check it out.
    PS Compressor £313 trade at connect(non-returnable).
    Mike.
    #172269
    That’s positively scary!
    Beever
    I have been to three of these appliances, 2 with the cooling fan @ the bottom front coming loose causing fan to jam/ be noisy and one with fan fitted in reverse, sucking instead of blowing!
    Very clever in principal, takes an age to dry.
    Basically, the condenser is refrigerated and the waste heat from the comp is channeled into the drum to dry the laundry!
    Brilliant! A+ energy rating (a fridge that dries your washing)
