regulations for installing a gas hob?
Home Forums Public Support Forums Help And Support Cooker And Oven Forum regulations for installing a gas hob?
  • #15111
    ali-b
    I am in the process of designing the layout for my new kitchen which is to include a built-in double electric oven and a gas hob.
    Can anyone please tell me what the legal requirments are in regards to the distance the hob must be from the housing unit for the double oven and the distance the wall units must be above and to the side of the hob.
    The hob is 68cm wide, the wall units will sit 35cm above and start 5cm away from either side of the hob. The double oven will be 36cm away from the side of the hob.
    Hope someone can help.
    Thanks.
    ali-b.
    #162144
    Re: regulations for installing a gas hob?
    hi
    the following is required
    cooker hood 760m above gas burners
    50mm away at side of hob
    hope this helps
    bryan
    #162145
    ali-b
    Thanks for your quick response. looks like I should be ok.
    Ali-b.
    #162146
    Bill
    The hight above the gas hobb is dependant on the manufactures minimum apart from what GORGI insist.
    Bill Ellis :scot:
