Relays. What is the difference between SPCO & SPDT?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Relays. What is the difference between SPCO & SPDT?
  • #59027
    Same relay, same manufacturer, same part number.
    RS describes it as single pole double throw (SPDT)
    Farnell calls it single pole change over (SPCO)
    Why two terms for the same thing, or am I missing something?
    Schrack / Tyco RT314024
    Mike.
    #336524
    Re: Relays. What is the difference between SPCO & SPDT?
    they are the same thing just a different way of describing
    change over relay changes over from 1 contact to the other
    therfore has 2 positions so double throw
    same action as a 2 way switch
    hope this makes it clearer
    Strange. I always imagined a double throw meant there would be a midway position where neither contact was made, hence switch would need to be “thrown” twice to get from one side to the other. Couldn’t figure out how that would be achieved inside a single relay. Very annoying (to me) that there isn’t more standardisation of the terminology.
    Mike.
    #336526
    to do that in a relay would require 2 coils or using a dc coil and reversing polarity
    dave
    #336527
    Well thanks for the replies Dave. At least I now know I can go ahead with the order.
    Mike.
