Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Reminder Zanussi w/d, wierd faults caused by dryer heater
- This topic has 7 replies, 6 voices, and was last updated 8 years, 1 month ago by
pmb.
February 16, 2018 at 5:40 pm #93350
pmb
ParticipantHad a Zanussi Washer/Dryer today display not coming on.
As soon as I disconnected dryer heater it’s OK, so I just have to
Replace element, can be all types of symptoms caused by this
I know all the experienced engineers will check this.
But if you are new to the trade machines might get righton off
as it’s not a obvious causeFebruary 16, 2018 at 5:43 pm #454042electrofix
ModeratorRe: Reminder Zanussi w/d, wierd faults caused by dryer heate
get fault like this a lot these days. heaters are well known by us to cause all sorts of problems as soon as there is a leak to earth. Bosch wash heaters is another one.
just does not make any logical sense to the symptoms your gettingDave
February 16, 2018 at 7:20 pm #454043Martin
ParticipantRe: Reminder Zanussi w/d, wierd faults caused by dryer heate
pmb wrote:I know all the experienced engineers will check this.
I’m delighted to hear you solved the problem pmb and I get where you’re coming from regarding experience. But experience is primarily gained by applying the basic procedures toward initial fault finding from the start.
You no doubt quickly found this fault using a basic insulation test procedures the moment you clapped eyes on the machine. And your post intended to direct others into doing just that.
So a good moment for me to direct others into realising the benefits of such fault finding techniques by providing a useful link below. I wrote the article years ago and it features a basic analogue insulation tester. Many of you opt for the digital equivalent, which is the preferred tool these days, but hey I’m old school. 😕
February 16, 2018 at 7:38 pm #454044kaibart
Your spot on Martin without carrying out these tests faults can be overlooked
February 16, 2018 at 8:28 pm #454045alster
Would i be right in thinking we should be looking for 0.1 ohm earth continuity these days??
February 17, 2018 at 3:52 pm #454046Martin
alster wrote:Would i be right in thinking we should be looking for 0.1 ohm earth continuity these days??
Yes 0.1 to 0.5 ? between the plugtop earth pin and machine cabinet is fine. 😀
February 17, 2018 at 5:59 pm #454047eastlmark
having said that, often these Electrolux dry heaters read fine when cold. Its only after they have been on for a while the insulation drops and then can quickly regain their integrity by the time you have untangled your meter leads. Guessing a lot of experienced engineers have found this out the hard/expensive way.
February 18, 2018 at 7:59 am #454048Martin
eastlmark wrote:having said that, often these Electrolux dry heaters read fine when cold. Its only after they have been on for a while the insulation drops and then can quickly regain their integrity by the time you have untangled your meter leads.
That’s why it is important to test before, during and after the repair is carried out. As stated in paragraph 2 (page 1) of my publication. 😉
Basic procedures that speed up diagnosis, repair time and cost.
