Removal of a built under double oven
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Removal of a built under double oven
  • #77092
    bristol
    I have a Diplomat ABA 4540 built under double oven which I need to replace.
    It sits on runners fitted to both the oven itself, and to the adjoining kitchen units.
    Looking at You tube videos it seems a simple matter of taking the doors off and sliding the oven out, but the thing is stuck fast.
    The “manual” I have simply refers to the runners being fitted and I cannot see any other fixings, yet the thing refuses to move.
    Any thoughts or advice greatly appreciated.
    #400977
    knobs
    Re: Removal of a built under double oven
    I had a similar problem with a diplomat,i had to lift the oven up slightly and then pull,i think what happens is the machine being quite heavy,sinks onto the runners,have 3 weetabix and have another go !
    #400978
    bristol
    Thanks for getting back – i’m a strong boy but took your advice and the bugger is still stuck fast! – its also decided to stop working in protest at my plans to replace it. Hopefully a specialist coming in next Tuesday can work his magic..
