I have a Tecnik DW2677 fully integrated dishwasher which I inherited without the installaton or user guide when I moved into my current home. The handle has come loose and fallen off the front leaving the screw threads exposed and I need to remove the wooden panel to put it back on.
Has anyone any idea on the technique for removing the front panel as I want to avoid damaging it
Re: Removal of Front Fascia Panel on Tecnik DW2677 Dishwashe
Whirlpool machine.
Undo by two turns the 2nd and 4th screws on each side of the inner door panel. Raise the door almost closed and push the outer door down. It should fall off.
