remove pulley from bosch motor shaft
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum remove pulley from bosch motor shaft
  • #88463
    chrisday
    Bearing requires replacing from Bosch Tumble Dryer shaft which neccesitates the removal of the belt pulley fom the end of the armature shaft. Have tried unscrewing and use of medium heat to no avail. Has anyone had the experience before?
    #438192
    Re: remove pulley from bosch motor shaft
    Full model number (ENr number ) required please?
    #438193
    aqualectric
    Pulley is not removable; they are fitted on a sprung grab collar that sits in a groove and the pulley is pressed on. Not that removal of these pulleys on driers and washers hasn’t been tried in vain over many years by the trade – new motor only if bearing is noisy. If you damage the pulley or the grooves then the motor assembly is scrap anyway as no individual parts are available. Unfortunately the manufacturer has deliberately dictated your next course of action with non – repairable parts and the disproportionately high cost of replacement spares. 😉
    As Martin says, full Enr. and FD numbers required to go further with pricing new motor.
