Re: remove & replace decor door on White Westinghouse di
White Westinghouse dishwasher model number is 02-200470 manufactured 1999 but hardly used; serial no is 991613429 which may define country of origin, model type or precise date of manufacture.
It’s an Antonio Merloni machine. Door is probably retained by two screws through the side of the door panel. Slacken them off a few turns and the door should slip forward, allowing you to lift it off the bottom lugs.
This was not the most secure fixing ever invented – there are often a couple of supplementary screws running straight through the edge of the door.
