Removing drain hose with 2 lugs from pump Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Removing drain hose with 2 lugs from pump This topic has 2 replies, 2 voices, and was last updated 6 years, 6 months ago by pmb. Viewing 3 posts - 1 through 3 (of 3 total) Author Posts September 24, 2019 at 1:10 pm #96438 pmbParticipant I sometimes have to remove Bosch drain hose from pump, this is the one with two lugs ether side you have to press, how do you do it, I suppose they make a special tool , have you got a tip September 26, 2019 at 4:00 pm #463391 pmbParticipant Should have read Removing drain hose from pump October 4, 2019 at 8:03 am #463392 groosterParticipant From memory, they twist around about half way and then you can pull it out. Same for putting it back in. Locate, push and twist. Author Posts Viewing 3 posts - 1 through 3 (of 3 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
