I have a Panasonic NA-147VB5 Washing Machine. It has an Error code EO1 which according to Panasonic list of codes is the door lock.
I have now replaced the door lock but the Error code is still there, should the code have deleted automatically or do I have to delete the code from the Machine memory and if so how do I delete it.
Hi: I can’t actually find anything on re-emerging codes on your machine, so it may well automatically clear when the fault is no longer there. Unfortunately when it says door lock, the fault doesn’t have to be the interlock itself.
There could be a fault in the interlock wiring harness or on the control PCB itself, if the interlock itself was faulty then it could also have damaged the PCB. All these things need to be checked.
