Removing heater in a DeDietrich VZ9996E1 dishwasher
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Removing heater in a DeDietrich VZ9996E1 dishwasher
  • #35779
    Dazzlevision
    Hello,
    I’ve “Megger” tested the heater element and it’s flat to earth. It trips the 30mA RCD in the consumer unit.
    I’m having difficulty removing it. Once the single securing nut is removed, I can’t figure out how the element comes out?
    There is a gasket and (presumably) some sort of clamp plate inside the plastic housing…
    Any guidance gratefully received.
    Many thanks,
    Dazzlevision
    #248051
    Re: Removing heater in a DeDietrich VZ9996E1 dishwasher
    This is the heater at the front bottom of the machine? If yes, there is a compressed rubber gasket behind the metal front plate. A deal of careful levering is about the only way to remove it.
    Power off, of course.
    Dazzlevision
    Hello Penguin 45,
    Yes, it is at the front right hand corner of the machine.
    I think I’ll wait until I have the replacement part to hand and use that as a guide to how the original comes out!
    Many thanks,
    Dazzlevision
