Re: Removing Hygena built in oven door
repman wrote:Open the door and
3 or 4 inches from the hinge towards the top of the door you should have a screw when removed will allow the door to slide off the hinge arm.
Thank you. I have managed to get the shattered door off at last. I had been trying to remove the door and hinge together!
I am going to order a new door. Can you advise if it should just be a case of sliding the new door back on to the hinges?
Off now to find a good take-away!
Many thanks,
Anne
