Removing the front door panel from a Bosch washing machine
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Removing the front door panel from a Bosch washing machine
  • #57716
    justinbarrow
    I am to replace the door seal of my Bosch washing machine model number is: WAA24169GB/20 and have been advised that the front panel comes off but am having difficulty removing this.
    Its the main large front panel, I can see 2 white plastic clip/studs that appear to be holding it in place but i am not sure the best way to get round this.
    Are there any screws i should be aware off as i dont fancy trying to replace this seal with the front panel on if need be.
    Thanks for any help on this 🙂
    #332071
    clivejameson
    Re: Removing the front door panel from a Bosch washing machi
    As per the forum rules we can’t give you a ‘remove screw A’ type instruction, suffice to say there are two screws at the bottom of the front panel and one at the top 😉
    #332072
    nomadPaul
    clivejameson wrote:As per the forum rules we can’t give you a ‘remove screw A’ type instruction, suffice to say there are two screws at the bottom of the front panel and one at the top 😉
    Not on this model…..only 2 at bottom 😉
    #332073
    justinbarrow
    Thanks for this, there was 2 at the bottom. New seal now fitted and machine is back in action.
    Thanks guys
