Removing the lower cover of a LG F12B8QDA 7kg washer
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Removing the lower cover of a LG F12B8QDA 7kg washer
Viewing 1 post (of 1 total)
  • #85563
    DanielDeronda
    I have very recently bought an LG F12B8QDA 7gh washing machine from Currys (last Thursday had it installed etc).
    I have used it for a few different washes over the past week & everything went smoothly, my clothes were very clean & fresh & the machine was quiet.
    However, things went quickly wrong today! I got an error message OE & the cycle couldn’t drain the water & then spin to complete the cycle.
    I took the lower cover cap off to show a drain hose & a filter. As it was mid cycle, there was a lot of water to drain, which I did manually into a suitable vessel. THe hose is now empty. I also checked the drain pump filter & there is no debris or anything in it.
    However, when I went to attach the drain hose & drain plug back under the lower cover cap, the hose fell back into the hole & I’m unable to get it back.
    I assume I can take the whole of the lower cover off to be able to put the hose back in the right place.
    Can you let me know how I can get the drain hose back in the correct position?
    Let me know if you need any more info from me.
    Cheers
    DAN GOULDEN
