Info.please: Thermostat removal
Beko Fridge Freezer: CDA554W model (Beko A Class)
How do u detach the thermostat from the light housing? Does the temp. dial just pull off (tried to pull but didn’t come off)or is there a hidden screw?
Do you just pull the capillary tube out of the hole or do u need to remove the top cover of the fridge to feed it through?
Many thanks,
Kenneth
