Someone has sat on a control knob and broken the shaft. I need to replace said shaft, but how do I get behind the control panel? 😯 I’ve removed all the screws I can see, does the top of the hob just lift off hidden clips, or are there more hidden screws? 😕 Any help would be fantastic, as money is tight at the minute!!
Cheers, you are probably right as I cant see any screws to release the Hob top 😥 , so probably behind the side panels. Oh well, I’ll leave a note for the teenagers, no more lounging on the cooker!!
