Re: Removing Zanussi ZCG661GWC glass lid deactivates gas saf
The regulations are quite clear about this situation, you cannot remove the lid and then connect a cooker/hob to the gas supply. If you do so then it will be picked up at the next annual inspection, the appliance will be classed as immediately dangerous and the gas operative will need to inform the HSE.
Your choices here are to either move the wall units so that the lid can be raised to it’s open position with the minimum clearances as stated in the user manual or replace the cooker with one that has no lid.
John
