Re: Repair a Hotpoint Aquarius DF41 with error 20
What is the safety stat?
It manages to get all the way through a pre-wash cycle with no heat. However, for a wash cycle at 40C, it displays “No Heat” all the way through and so after the final rinse after 30mins or so, it beeps with the error 20. But, When I open the door, the steam feels hotter than 40C.
My guess, based on this is that it’s probably the temp sensor, which you reckon is located in the door.
Is it simply a case of removing the screws holding the back panel onto the door to access the sensor then?
Cheers, matey
