repair combine grill/oven element for built in Arrow help
Home Forums Public Support Forums Help And Support Cooker And Oven Forum repair combine grill/oven element for built in Arrow help
  • #51879
    TORTUE101
    Hi there,
    Im a single mom who cannot afford a repairman and i will attemp to change the Grill/Oven Element myself. Therefore i need advice on how to remove the back ( its built in the counter) to be able to change the faulty element? And would switching the main socket be enough?
    Any help at all would be greatly appreciated.
    Thank you
    Tortue
    #309656
    don
    Re: repair combine grill/oven element for built in Arrow hel
    Deleted your post in the spare parts forum, more help to be had here.
    A model number would help 😉
    Don
    #309657
    TORTUE101
    yeah sure
    Arrow oven model : TFA10GB09119900706
    thanks 🙂
    #309658
    Hello.
    The element required will be in amongst this group HERE.
    Please note that THE FORUM RULES are quite specific – we will not take you through the job screw by screw, wire by wire.
    Note that Arrow as a brand is dead, the manufacturer who supplied Arrow has also gone bust – long term, you’re on a hiding to nothing.
    If you feel that you have to try and get it going, the top and bottom elements are retained by screws from the rear, so removing the rear cover is your access point. The fan oven element is behind the panel in the back of the oven (Four screws from memory), although I think it is screwed from the rear.
    Make diagrams before removing any wire or fitting and isolate from the supply before touching anything.
    Penguin45,
    Moderator,
