Repair for Vestfrost Fridge
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Repair for Vestfrost Fridge
  • #73343
    PeterAC
    I have a Vestfrost fridge (model number KS385)in need of repair, does anyone know of an engineer who can help?
    I live in Farnham, Surrey.
    Thank you.
    #387149
    Re: Repair for Vestfrost Fridge
    As a guess its a 50/50 fridge freezer and the fridge has stopped cooling ?
    Bryan
    #387150
    PeterAC
    Its actually a large double door fridge – and yes it has stopped cooling.
    #387151
    http://www.ukwhitegoods.co.uk/search/find-an-appliance-engineer.html
    The fault will be the same as they use the same cabinet for fridges & freezers and fridge freezers.
    It will most probably need a extra long capillary thermostat which is a standard part.
    Have you tried to do a search ? Link above
    Bryan
    #387152
    PeterAC
    Yes I have used the search engine but it didn’t provide a result for my post code.
    #387153
    If i am right there is a metal plate on the back wall of the fridge which is what would normally cool down. if so the following is the thermostat. Yep there doesnt seem to be anyone listed.
    http://shop.ukwhitegoods.co.uk/vxo-univ … thermostat
    You would need allen keys and a phillips screwdriver and long nose pliers to fit if you wanted to carry out the repair yourself.. :zap: :zap: remember power OFF :zap: :zap:
    Bryan
    #387154
    PeterAC
    Hello Bryan,
    Many thanks for your help and advice – I’ll have a look at the back as you suggest. Thanks for the link for the part as well.
    Regards
    Peter
