Repair or Replace : OKO-LAVAMAT 1271 ?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Repair or Replace : OKO-LAVAMAT 1271 ?
  • #48363
    Dockland
    I have a AEG Oko-Lavamat washer dryer that I have owned for 11 years, last weekend it started oozing smoke and stopped working.
    A lot of comment s I have read suggest it might be the drum bearings, but I not knowledgeable enough about these things to say if that is the case or not.
    Now I have the choice of repairing or replacing. The problem with repairing is that I would have to pay a call out charge get someone in, they assess the problem and make a judegment on wether it is worth repairing.
    I wondering if this is worth paying or just biting the bullet and buying a new machine
    #296402
    Re: Repair or Replace : OKO-LAVAMAT 1271 ?
    A new washer dryer of comparable quality would cost several hundred pounds more than most repair jobs you might need on the AEG so I would recommend you get someone to look at it. If you buy a new AEG machine it will probably be of inferior quality to your current model.
    #296403
    Dockland
    Hi Phidom
    Thanks for the reply.
    Out of curiousity do you know what is the normal lifespan for a Washing machine.
    Is a 10 year old machine generally considered to be at the middle or end of its expected life span?
    #296404
    With average use of say one wash a day I would expect a German made AEG to last at least 20 years. If you bought a new Indesit today you would be lucky to get more than 5 years.
