Repair sagging drum Miele W310
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Repair sagging drum Miele W310
  • #92683
    ocular
    Have a Miele Novotronic W310 cirrca 2004 era. minimal use – but drum has dropped downwards and no longer centred on door opening. Door rubber seal is distorted and drum starting to rub on clear window. The drum bearings seem fine.
    Presume the drum suspension needs attention. Is this just likely to be 4 drum support springs or is the suspension more complicated on this unit. Havent opened it up yet.
    thanks
    #451887
    Re: Repair sagging drum Miele W310
    till you open it you wont know. there will be springs at the top holding the drum up and if one has snapped it will cause this
    if spring has snapped has the unit been banging round a lot recently ? had this problem on other machines and worn shock absorbers cause springs to over extend and snap
    ocular
    Thanks. So its likely that 4 suspension springs and 2 damper arms would be the minimal parts required to repair this problem in this model.
    #451889
    2 shock very probably
    springs only replace if they have snapped. may have just come unhooked
