Repairs@ 2
Home Forums UK Whitegoods The Board Room Repairs@ 2
  • #9417
    Kev, have you been charting the raw cover on Repairs@ on a Mappoint file?
    I want to push that a bit and I need a bit of info for the tactics I use. And I know I’m an impatient bastard, but I have something in mind. 😉
    Dave_Conway
    Re: Repairs@ 2
    Same as the one I had at P&G on the lappy ?
    #133967
    Na, that was the raw cover map, I know about that one but does that tie up with Repairs@?
    Re: Repairs@ 2
    I’m not able to do repairs@ covering ALL individual bussiness as I can only cover 1 postcode with one agent in Mappoint. The primary map is not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} accurate as a few of them are not on Repairs@ and for instance we have not included a couple we do not want (considering the size of area)
    However if you want a political map of the areas covered by repairs at I’ll knock one up today.
    All one colour, postcode areas only (not district) will highlight the gaps. For greater effect may be better to split the map (remember the four way split from the MFI original map?) to allow a bigger map size on your post. The map of the UK in A4 size will not show great detail of the uncovered areas.
    Whilst we do have overlaps in some post codes I can’t think how to show it. Can’t even do it by skill set as we all do washers!!! And the gas coverage would look crap!!
    #133969
    Right, I thought that may be an issue. 🙄
    Okay then, how about we set a low/medium/high level of cover based on your assesment of the codes and just use different colours to represent the level of cover? It’s simple and easily viewed as well as pointing out the target areas on several levels.
    Del
    Re: Repairs@ 2
    Any chance of posting up a copy of the map in this forum so I can see who’s doing where !
    Might be interestin’
    Sean
    #133971
    Do you have Mappoint Sean?
