Repeated breakages of Hotpoint oven lamp cover
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Repeated breakages of Hotpoint oven lamp cover
  • #25652
    nojo608
    I have built-in Hotpoint BU72P oven.
    Since new, every time the oven switches on, the lamp cover shatters.
    The lamp cover screws into the rear oven liner and I assume the latter expands, when the oven heats up, compressing and shattering the lamp cover, leaving the bulb exposed.
    Hotpoint are typically gormless about this.
    Does anybody have any suggestions, please?
    #206871
    Re: Repeated breakages of Hotpoint oven lamp cover
    I haven’t heard of this personally but can only think that perhaps the lens has been either overtightened of cross-threaded into the back liner maybe?
    Replacing the lens and the rear oven lining may be the solution?
    #206872
    nojo608
    Thank you.
    I wonder if there’s a fault with the thread in the rear liner, because I would have thought that it would be designed to leave space for expansion, without pinching the lamp cover.
    Might be fun persuading Hotpoint to conduct a warranty rear liner replacement however?!
    #206873
    The liner is only about £15 or so, maybe best to get it replaced anyhow. 😉
    #206874
    clivejameson
    IIRC some lamp covers have a soft alloy washer underneath them which would obviously protect it from heat expansion.
    What’s the model number of your oven?…..I’m sure someone here with the correct manufacturers technical info 😉 will be able to tell you whether a washer is required…
    #206875
    clivejameson
    Forgot to add…..when you fit a lamp cover, never tighten it all the way….just ‘nip’ it up, then the worst that could happen is it will loosen and rattle slightly in which case it can be retightened.
