Replace bearing on aqualux 1000
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Replace bearing on aqualux 1000
  • #20312
    hassy
    electrolux Aquyalux 1000. Is it possible for a DIY mid novice to repair the bearing on this machine.
    Thanks Hassy
    #186606
    Re: Replace bearing on aqualux 1000
    Various types of drum, so tell us the model number, please.
    hassy
    EW 1000 I
    Electrolux aqualux 1000
    Intergrated
    Does this help
    Regards
    Hassy
    #186608
    Yup, nails it down nicely. This machine requires you to split the casing and remove the entire drum assembly in order to change the bearings. A complete cow of a job – most repairers will allow two hours on site to do the job; some may even uplift it as a workshop job.
    Apart from that, basic hand tools and a seriously large hammer and drift are all that’s required.
    Bearings and seals may be purchased through the spares@ukwhitegoods.co.uk facility on the site, as can the drum support , if required. Given the level of dismantling required, I would suggest that you check the condition of the drain pump and motor brushes whilst it’s all apart.
    hassy
    Thanks a lot
    Panic stations!!!
    Hassy
