Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Replace door seal – Zanussi FJS 1225W
- This topic has 4 replies, 3 voices, and was last updated 17 years, 7 months ago by
KMD.
August 15, 2008 at 9:41 am #38763
KMD
ParticipantMy clothes are sometimes suffering staining which seems to come from deposits on the door seal that I cannot remove. What is causing this? What can I do about it?
Assuming that after several years of use I now need a new door seal, is this something I can change myself (I have quite good DIY skills) or should I call in a specialist? I know I can purchase the replacement part from whitegoods.
August 15, 2008 at 10:54 am #259928don
ModeratorRe: Replace door seal – Zanussi FJS 1225W
Hi KMD
This happens a lot nowadays due to the low wash temperatures used. There are some good articles to be found in our advice and help section
If the problem is serious then perhaps replace the door seal. To keep the new one clean Click here to purchase Affresh washing machine cleaner which will help keep your machine in tip top condition.
As for the fitting of a new seal click the ” find an engineer ” link in your post, it could save you pounds and hassle in the long run 😉
HTH
Don
August 15, 2008 at 11:04 am #259929KMD
ParticipantDon, many thanks for your comments.
Will also check other articles on the subject.
Will try using Affresh before deciding if problem serious enough to warrant changing seal.
I think I will opt for engineer to change seal if required.
Regards, KMD
August 15, 2008 at 11:24 am #259930cockney steve
ParticipantRe: Replace door seal – Zanussi FJS 1225W
In desperation, you could use neat bleach on the rubber,making sure you open the folds back in order to kill the “hidden” mould. (rubber gloves and a saturated dish-cloth work well ! )
you should then rinse the rubber well and probably do a hot,whites wash as your first, following bleaching.
You can also get a “bathroom black mould ” cleaning spray at supermarkets.
Another well known old-fashioned remedy is WHITE VINEGAR (same method as bleaching,but kinder to the rubber and ,of course, needs an empty wash to eliminate the smell of vinegar afterwards.
Once it’s clean, the affresh should keep it that way.
August 15, 2008 at 12:23 pm #259931KMD
ParticipantSteve, many thanks.
Your advice much appreciated.
KMD
