Replace Drum Paddle On A Daewoo DWD -G1241S
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Replace Drum Paddle On A Daewoo DWD -G1241S
  • #78992
    coffs
    Hi, how do you replace the drum paddles on the Daewoo DWD -G1241S please.
    #407538
    Re: Replace Drum Paddle On A Daewoo DWD -G1241S
    coffs wrote:Hi, how do you replace the drum paddles on the Daewoo DWD -G1241S please.
    It just clips into place see HERE
    #407539
    coffs
    There seems to be a screw at the rear holding it in place
    #407540
    coffs wrote:There seems to be a screw at the rear holding it in place
    Then you might need to remove the bottom hose in order to access?
    #407541
    coffs
    Hi, took the top cover off and it looks as if you need to remove the larger hose from soap tray, but it is on the side of drum and cant see how you get side panels off to get access to it?
    #407542
    coffs wrote:but it is on the side of drum and cant see how you get side panels off to get access to it?
    Isn’t it a welded cabinet on this Korean masterpiece? Access via the bottom hose is the usual option on machines with welded cabinets.
    #407543
    Andy jones
    Can’t think of many machines where the sides come off
    #407544
    MickGeorge
    Hi Folks
    Got one of these to do tomorrow. Just trying to get a bit of heads up before I go. Was access to the screw through the sump hose or did you have to get the dispenser hose off?
    Or if anyone else done one of these help gratefully received.
    Done them on Hoovers where access is through the sump hose but not sure on this as not been yet.
    Mick.
