Replace Integrated Fridge
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Replace Integrated Fridge
  • #87462
    foxy1
    My old small integrated under counter fridge has finally given up the ghost after about 20 years loyal service and I was thinking I might replace it with an ordinairy (ie non integrated ) type.
    I just if this would be a straightforward job and if anyone had any advice
    #434932
    Re: Replace Integrated Fridge
    Replacing it with another approx 60cm integrated fridge shouldn’t be any big problem and personally I would opt for a Liebherr one.
    On the other hand replacing it with a standard one will be a bigger problem finding one the correct hight,width, and also the depth to allow you to still keep your decor door attached using a standard set of hinges.
    Bryan
    #434933
    foxy1
    I’m not bothered about about using my decor door thats why I thought about an ordinary fridge
    #434934
    Always keep your decor door though..Even if you just put it into the loft as if and when you sell the property it would be beneficial for the new owners as they probably wouldn’t be able to get a door to match.
    Bryan
    #434935
    foxy1
    good advice r600a but my kitchen is as old as the fridge!
    #434936
    Even more of a reason to keep it.
    Bryan
