Replace Top left grill in Flavel Finesse 100 FN10FRK
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Replace Top left grill in Flavel Finesse 100 FN10FRK
  • #86941
    mjridley
    I own a Flavel Finesse 100 FN10FRK. The other day there was a bang and the top left grill (Above the convection oven) has stopped working. Part of the grill element is fatter and looks like it has blown.
    When I checked the back of the oven, the point where the white/blue cable entered the electric connector box looks like it had melted and the end of the cable was black.
    My first question is, once I have the back of the oven off, how do I get to the Grill screws to undo them to remove the grill element.
    My Second question is that as I mentioned the electric box on the back of the oven had melted where the white/blue cable (Presumably connected to the grill element) was connected.
    Am I ok to just replace the electric connector box or is the fact that this also appears to have also blown a bigger problem.
    Thank you in advance
    Matt (NB I am just a DIYer)
    #433462
    Re: Replace Top left grill in Flavel Finesse 100 FN10FRK
    Should be two screws, one either side of the rear mounting plate on the element that allows you to draw it forward and out.
    There’s two, genuine and a compatible that will show you the plate and element out:
    http://shop.ukwhitegoods.co.uk/46292000 … ll-element
    http://shop.ukwhitegoods.co.uk/ele2069- … ll-element
    Relatively easy once you work it out.
    mjridley
    Hi kwatt,
    Thank you for your reply and your advice. I will give it a go.
    Matt
