I am trying to replace a failed thermal cutout on my Leisure (Beko) range cooker model HJA 5093. The cut out protects the timer and main fan oven. The replacement part SKU 210110549 does not have electrical continuity when tested with a multimeter. I have tried 2 new replacements without success. The top oven/grill on this cooker has an identical cutout which has not failed and I have now successfully used this to replace the main oven cut out leaving the top grill non functioning. The unit from top grill/oven was testing OK on the multimeter. Has anyone come across this problem with new thermal cut outs? The model number of the cooker is 7757586336-08
Thanks Dave
That is the part I have received – one from ukwhitegoods, the other from partmaster – neither of them will pass a current at room temperature! I have ordered another from espares to be received later this week – will post again with update
