Replacement cut-out/stats for Hoover/Candy t/d heater elemen
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Replacement cut-out/stats for Hoover/Candy t/d heater elemen
Viewing 5 posts - 16 through 20 (of 20 total)
  • #332032
    loopey
    Re: Replacement cut-out/stats for Hoover/Candy t/d heater el
    hoover part number for the 1 shot thermal fuse is 40001753 been using them for a while had no problems 🙂
    hth phil
    #332033
    electrofix wrote:or why white knight give the cutomer a restet button
    or why you can reset some stats but not others
    That’s a point too. But once customers know about that reset button, some of them will go on pressing it before every cycle until nothing works anymore rather than call you out :rolls: .
    Mike.
    #332034
    Bernie
    Thanks for the part number for the one shot thermal fuse loopey.
    You wouldn’t happen to know part number for the other one the blue spot?
    Bernie
    #332035
    Bernie
    Loopy you said that you have been using the 1 shot thermal fuse, part number 40001753 and you have had no problems.
    I cannot see how this will work as the thermostat is 130deg and that one-shot (part number 40001753) is only 85deg. The original one-shot on the heater is 206deg.
    #332036
    Bernie
    I have finally found a supplier for these thermal fuses
    Get them from :-
    www1.conrad-uk.com
    Then search for:-
    Thermal Link 155431.006D02 206 C
    £5.28 each
