Replacement door seal for unknown make of fridge
Home Forums Public Support Forums Spare Parts Help Replacement door seal for unknown make of fridge
  • #7313
    I have a fairly old fridge built-in to a fairly old kitchen and wish to replace the fridge magnetic door seal. The ID label inside the fridge by the salad drawer gives the various specs of the appliance and it is obviously of German manufacture. The “Type” is shown as “KE 2423-1”. There are no other markings to indicate the manufacturer.
    Is there a specific seal you can identify for this fridge?
    If not, is there a universal type of seal which would fit?
    Where can I buy one?
    Any help would be very much appreciated.
    Thanks, Ros
    #122628
    Dave_Conway
    Re: Replacement door seal for unknown make of fridge
    Ros, could you post up everthing on that plate please, I think it’s a Bosch or an AEG but the number you have already supplied isn’t recognised.
    There are “universal” door seals available but to be frank, they are a nightmare to fit and even then they don’t really work very well.
    #122629
    Thanks for the prompt reply Dave. Hope this is of some use to you:-
    Ersatzellindex B
    Klasse N
    Netzspannung 220V 50Hz
    Nennaufnahme 140W
    Kaltemittel R12 0.085Kg
    Kaltesystem Kompressor
    Bruttoinnalt 238 L
    Betriebsubarduck Saugs. 12 bar
    Drucks. 40 bar
    Dichtheit gebruft
    Nr.
    1301868
    All this info is on a paper label near the bottom of the left side fridge wall in the area of the salad tray. Most of the info is clearly legible but I’m not certain of the final 7 figure digit – the 8’s could possibly be 9’s.
    Good luck with that! Thanks, Ros
    #122630
    Dave_Conway
    Ros wrote:Good luck with that!
    None I’m afraid, sorry 😥
    #122631
    O.k., thanks for that. If no-one else has any ideas I’ll try a universal type door seal. Any suggestions where I can buy one?
    I tried Ezee-fix before Xmas but they don’t do them anymore.
    Ros
    #122632
    Dave_Conway
    Yes, I can get them, in fact I may even have one somewhere.
    If you measure the door I’ll let you have info for the closest match.
    #122633
    Good morning Dave,
    I’ve measured the existing door seal. It’s 54cm x 116cm around it’s exterior edge so that’s a total of 340cm all the way around.
    Hope you can help,
    Ros
    #122634
    Dave_Conway
    I have a universal one here, the description is:
    “UNIVERSAL 130 x 70cm Contains 2 Ready Welded `L’ shaped Gaskets 2 Corner Joints 1 coil Magnetic Strip Superglue and Fitting Instructions”
    You have to cut it to size and form/glue two of the corners.
    Yours for £12.50 inc VAT and carriage if you want it.
    Drop me an email and I’ll arrange for you.
    #122635
    Thanks Dave,
    e-mail on it’s way to you. Ros
