replacement for an old arrow/B&Q built in electric oven
Home Forums Public Support Forums Help And Support Cooker And Oven Forum replacement for an old arrow/B&Q built in electric oven
  • #52660
    LucyClasby
    Hello, i hope someone can help me find a replacement!
    My old Arrow oven has stopped working and it’s time to replace it but the dimensions seem a lot smaller compared to the current ovens on the market. My recess dimensions are 580mm H x 560mm W x 600mm D . The Arrow oven has a width of 530mm which seems a lot smaller and hence is making it harder to find a replacement.
    So far most ovens i have seen have a minimum width of 560mm W which is too big 🙁 I Hope someone can provide some alternatives that will fit the space.
    Thanks!
    Lucy
    #312638
    don
    Re: replacement for an old arrow / B&Q built in electric
    Hi Lucy
    I don`t know of any that springs to mind, but I`ll have a look on Monday when I`m back in the shop.
    Don
    #312639
    LucyClasby
    Thanks for the reply don, enjoy your weekend!
    #312640
    don
    Hi Lucy
    Hold on a minute 😆 I have just re read your original post. The recess dimensions you have quoted if correct is you have 560mm width available. Single ovens are just shy of 560mm wide which is pretty much standard nowadays. For instance Neff come in at 559mm and Hotpoint at 558cm. You have plenty of height as well as depth. So replacing the old Arrow should be no problem.
    HTH 🙂
    Don
    #312641
    LucyClasby
    Hey Don, thanks very much for checking. I popped into comet and the ovens on display indesit, beko and proline all measured larger than 56cm, only a delongi seemed to fit at 55cm! Will make another trip with my tape in hand! Will let you know what i find!
    x
    #312642
    petalpop
    remember the measurement you need to do is across the width of the body of the oven not across the front
