Replacement for Ariston Integrated FModel number: ON-ME 160L
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Replacement for Ariston Integrated FModel number: ON-ME 160L
  • #44166
    ed123
    Ariston Intergrated Fridge Model number: OK-ME 160L
    I have the above fridge which after switching off will not restart again. The light is on, buit there is no cooling at all!
    I would be grateful for some advice on repair or replacement. I have searched but had no success.
    Ed123
    #280025
    don
    Re: Replacement for Ariston Integrated FModel number: ON-ME
    Hi Edd
    As far as a possible replacement is concerned, the information I have available is a little sparse. Can you let me know the height and width of the appliance please? Does it have a solid kitchen door or a thin 3mm panel slid in around a frame? Does the existing machine slot into a housing at waist height?
    Don
    Electronic fridge thermometer click here
    #280026
    ed123
    Hi Don
    Thanks for geting back to me. Sorry it has taken a while for me to reply. The fridge (larder fridge, no icebox) is approx 34inches high (85cm) by 21 1/2 inches wide (53cm). As for it’s height off of the ground it is at waist height. (or a bit higher than waist height). It is approx 42 1/2 inches (107 cm) from the kitchen floor and approx 36 1/2 inches (93cm) from the bottom of the cupboard it is in. The fridge has a solid door and a solid kitchen door attached to it by a two metal bar slot system, one bar at the top and one bar at the bottom. (hope this describes it ok!)
    Thanks for all your help with this.
    Ed
    #280027
    don
    Hi Ed
    Thanks for the info. The sizes you have given indicate it could be a built under counter fridge installed as a column appliance and made to fit. To make sure we get any replacement recommendation right the follwing links should explain where I`m coming from 😉 the first link is an under counter fridge or this one which would install at waist height known as a column fridge.
    HTH
    Don
    #280028
    ed123
    Hi Don
    Thanks for the info. Looks the right type of replacement albeit an expensive one. I have some time so at first I will maybe remove it from the housing with a view to repair. I will give it a shake! Thanks for all your help and speedy advice.
    Ed
    #280029
    don
    Ed
    Hope nothing drops out :snig:
    Don
