Replacement for Ariston k/RF-3100 fridge freezer
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Replacement for Ariston k/RF-3100 fridge freezer
  • #91830
    phil-1982
    I have to replace an Ariston built-in integrated fridge freezer model K/RF-3100. It’s a 60/40 split, and the dimensions are 1772mm (height) x 543mm (width) x 550mm (depth).
    I couldn’t find this Ariston model at all. I wonder if someone knows whether there is an equivalent Hotpoint/Indesit model replacement?
    Thanks for your help!
    Phil
    #449414
    don
    Re: Replacement for Ariston k/RF-3100 fridge freezer
    50:50 is the most popular split followed by 70:30 and then 60:40 which is the least popular. As a result there are a couple of Miele here there are a few more here but sdaly no Hotpoint group models.
    Just be aware you can get fixed hinge or slider system hinges.
    HTH
    Don
    #449415
    phil-1982
    Hi Don,
    Thanks for your suggestions! The Miele are nice but rather expensive 😛
    The 60/40 are definitely more expensive than 50/50 or 70/30 models.
    Thanks again for your help.
    Phil
    #449416
    don
    A cheaper way would be to remove the wooden decor doors but you would lose the “integrated look.”
    You could then slide a 55cm wide freestanding fridge freezer in there like the Hotpoint RFAA52 or the Montpellier MS170. Both are available in frost free as well.
    HTH
    Don
    #449417
    phil-1982
    Hi Don,
    Best regards,
    Phil
