Replacement glass for philips series 90 built in Oven
Home Forums Public Support Forums Spare Parts Help Replacement glass for philips series 90 built in Oven
  • #7397
    I am unable to find a supplier of replacement inner glass panel 480×360 for this oven. Is there an other oven with the same glass size or can one be ordered to size?
    Alternatively, what solid heat resistant material would be suitable to replace the glass?
    Appreciate your advice.
    Alb
    #123026
    Dave_Conway
    Re: Replacement glass for philips series 90 built in Oven
    If you could check around the door for the model number I’ll check out whether the glass is still available for you 😀
    #123027
    Thanks Dave
    the (faint) numbers on the door are;
    15040 Ba 337000979
    Mod – axb 490/ph/01
    Hope the above makes sense. Appreciate your help.
    Al
    #123028
    Dave_Conway
    Sadly now obsolete I’m afraid 🙁
    Anyone got a Whirlpool inner glass they can measure for Al Please.
    #123029
    Thanks for trying. Is there any other material that is safe to use in place of the inner glass? (ie so that we can use the oven, even if we cant see inside without opening?)
    We plan to change kitchens later this year so only a temprary (but safe) use is required until we know what we will be buying.
    Al
    #123030
    Dave_Conway
    Nope, it’s reflective glass, it has to be that I’m afraid.
    I’ll have a look at some doors I have here, one may be suitable.
    #123031
    ASD in Morley keep a lot of old stock – 0113 3936688. Might be worth a call if you’ve got the part number.
    Just checked with ASD. They didn’t recognise the model number. Have I got a letyter or the number wrong do you think?
    Al
    #123033
    Dave_Conway
    Yes, it should be AKG490…. they may still not recognise it as the model is obsolete and no longer listed by Whirlpool.
    Give it a try though 😀
    #123034
    Thank You
    They say they can get it so have ordered it.
    Hope it turns out to be the right one.
    Your help very much appreciated and this site will be recommended.
    Cheers
    Al
    #123035
    Re: Replacement glass for philips series 90 built in Oven –
    Hi Dave
    Well the glass arrived, and it fits perfectly. But,, (there’s always a but!)
    The new glass has two 8mm fixing holes in it. This oven door fixes with clamps at the side of the glass however. Is it safe to use with the holes, or should I blank off the holes with (say) a flat head bold and nut as it would have if it were fixed thought the holes?)
    Al
    #123036
    Dave_Conway
    It sounds like that’s just the handle fixing holes if they are at the top.
    You could blank them off yes, but it won’t make a lot of difference if you leave them as they are to be honest.
    #123037
    Thanks Dave
    The holes are at each side of the glass, near to where the clamps are.
    As long as its safe that’s great.
    thanks very much for your help, will spread the word about this site.
    Al
