Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Replacement heating element wiring
- This topic has 12 replies, 3 voices, and was last updated 12 years, 5 months ago by
Mainstage.
November 10, 2013 at 2:33 am #78023
Mainstage
ParticipantHi, I’ve just purchased a replacement heating element for a Hotpoint Optima CTD80 (C00145747).
The one I am replacing has 2 orange wires to one thermostat and blue wires to the second (orange to 5 contact connector and element, blue to heating element and a single spade connector). The replacement has the 2 thermostats linked and only orange wires.
Leaving blue wires un-connected does not work, using original method without link wire and dryer works for 1 minute then stops. Any suggestions on how I should proceed?
Regards
November 10, 2013 at 10:23 am #404216iadom
ModeratorRe: Replacement heating element wiring
Yes, get the correct heater assembly, there are four different types, not interchangeable.
NB, there is only one stat, the other is an ntc. 😉
Full serial number needed to ID.
Sent from my iPad using Tapatalk HDNovember 10, 2013 at 10:45 am #404217Mainstage
ParticipantRe: Replacement heating element wiring
Hi iadom
Thank you for replying. I purchased the assembly suggested by UK Whitegoods following a request for information. There was no mention of variations!I guess I need to contact them again about an exchange! Unless any other solutions forthcoming from this community.
Regards
November 10, 2013 at 10:49 am #404218Martin
Mainstage wrote:I purchased the assembly suggested by UK Whitegoods following a request for information.
But you have only just become a member since yesterday and have never posed the question before.
November 10, 2013 at 10:56 am #404219Mainstage
Sorry, should have included that I emailed UK Whitegoods for information.
November 10, 2013 at 10:58 am #404220Mainstage
The full model details for my machine are:
Model: CTD80P
Ind Code: 95313560000
Serial No: 712070094November 10, 2013 at 11:02 am #404221iadom
You need C00260045. From serial number 71112.0000 the one shot was moved to the neutral circuit.
November 10, 2013 at 11:11 am #404222Mainstage
Thanks iadom, I’ve emailed them again with exchange request.
Regards
November 10, 2013 at 11:14 am #404223Martin
It looks like this….
November 10, 2013 at 11:51 am #404224Mainstage
Cheers Martin, I wonder if the heating elements are the same on both models?
November 10, 2013 at 11:54 am #404225iadom
Mainstage wrote:Cheers Martin, I wonder if the heating elements are the same on both models?
Both models ❓ there is only one model of CTD80 with three colour variations, the spec for the heater and components used has been changed four times though.
November 10, 2013 at 11:54 am #404226Martin
Doubt it, Hotpoint’s purpose in life is to confuse us all.:rolls:
November 10, 2013 at 12:09 pm #404227Mainstage
Un-surprising!
My thought was simply replace the new stat and ntc with the original components as they are still working, (only the elements were damaged). Seems simple but…!
