Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › replacement pipe?
- This topic has 6 replies, 3 voices, and was last updated 19 years, 6 months ago by
markmark.
October 1, 2006 at 7:48 pm #21315
markmark
ParticipantThis will sound really stupid but I need to replace a small pipe (about 12mm dia with 2 90 degree rubber connectors) between two parts on my dish washer.
I have no idea where I will get this from?
Are the 90 degree connectors and pipe avalible seperately and glued?
Are they avalible from DIY stores.Thanks in advance.
October 1, 2006 at 7:52 pm #190427Penguin45
ParticipantRe: replacement pipe?
Would you like to share which dishwasher with us?
October 1, 2006 at 8:11 pm #190428markmark
Ah yes, didnt think it would matter too much as it seems like a universal pipe.
Its a Beko D3731 dishwasher.The pipe is only about 150mm long, 12mm diameter, connected to a arm on the clear water holder (sorry Im not sure of many of the part names) and going into a large black pipe from the motor, just below the centre of the machine.
The dishwasher was in the house when we moved in and wasnt working, everything sounded fine but it wasnt filling up with water. I thought it may have been the water inlet valve but when I took the bottom off I seen a mouse/rat had eaten this small pipe.
October 1, 2006 at 8:30 pm #190429Penguin45
It’ll be made to measure, Mark – usually because of space restrictions, it will also be able to take pressure. I can’t find it on my rather limited Beko tech info, so hang fire, there’s a few trade lads who should be able to work out what you need.
Penguin45.October 1, 2006 at 9:11 pm #190430kwatt
KeymasterAn email to spares@ukwhitegoods.co.uk will get you answers Mark.
October 2, 2006 at 10:20 am #190431markmark
Thanks for your help, I’ll send an email now. Mark
October 3, 2006 at 12:13 pm #190432markmark
http://img154.imageshack.us/my.php?imag … hereq8.jpg
I’m getting no where trying to find this part, cant get through to the parts dept or anywhere else Beko related for that matter. parts@ukwhitegoods cant tell what the part is as the pictures they have from Beko are terrible.I’ve put a picture up of the part I need, its the small pipe with the black line down the middle.Who would have thought a small pipe could be so hard to replace.
If anyone can help It would be much appreciated.
Mark -
