Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Replacement red neon lens cover
- This topic has 10 replies, 3 voices, and was last updated 4 years, 4 months ago by
menderman.
December 3, 2021 at 7:03 pm #100311
menderman
ParticipantCDA Oven CD9002/1
I need a new red lens cover for the neon temp light but unsure which one I need. The old one broke and was so brittle other bits flaked off it so its difficult to see what it should look like.
I think it may of had little wings like this https://shop.ukwhitegoods.co.uk/a08011-orange-neon-indicator-lens
And how does that one fit into the hole – do the wings bend flat and then open out. Also do I then just push the neon section into it for a friction fit.
Also there is this one https://shop.ukwhitegoods.co.uk/a08000-orange-neon-indicator-lens but can not tell from the picture if it is the same as the above linked one. They also both say orange – is one just a darker orange than the other.
Not sure if mine is supposed to be red or a red/orange colour.
The neon part I have left is 7.22mm diamater- so I need the above part s to be able to take that.
ThanksDecember 4, 2021 at 11:02 am #480125menderman
ParticipantThinking I may as well change the whole unit with one of these https://shop.ukwhitegoods.co.uk/p093…indicator-lamp.
And just cut off the old one and crimp on a couple of spade connectors. But there are no measurements listed with the one on here – will it fit my hole ? What about wattage.Also the original is in two parts – a mushroom head which stays in the front panel and the separate push in neon – here is the neon section https://www.espares.co.uk/product/es…er-signal-lamp you can see the thinner end that pushes in.
Does the one on here I linked to work the same ? as I they need to be able to be unpluged to remove the front panel.
December 5, 2021 at 7:15 pm #480126menderman
ParticipantJust to add that the hole in the front panel is 8mm anyone know if this https://shop.ukwhitegoods.co.uk/p093040-rangemaster-oven-indicator-lamp will fit the hole please
December 5, 2021 at 9:24 pm #480127electrofix
Moderatormenderman wrote:Just to add that the hole in the front panel is 8mm anyone know if this https://shop.ukwhitegoods.co.uk/p093040-rangemaster-oven-indicator-lamp will fit the hole please
if you read the more info tag it says its 11.5mm
December 5, 2021 at 10:57 pm #480128menderman
ParticipantOh yeh that’s right and right at the top but I still missed it :eek:. But it dose not state what it refers to – is that the hole diameter or is that the external – wider part.
December 6, 2021 at 12:23 am #480129electrofix
Moderatormenderman wrote:Oh yeh that’s right and right at the top but I still missed it :eek:. But it dose not state what it refers to – is that the hole diameter or is that the external – wider part.
dont know that its not the sort of info they publish
try sending the shop a message and while you at it find out if they can get correct part
or by searching “neon panel lamp” you can get
https://www.ebay.co.uk/itm/122010995831?hash=item1c686c0c77:g:rMUAAMXQeW5TXfwq
December 6, 2021 at 9:02 am #480130tubafan
But is that the diameter of the hole it fits or of the outer lens, which will be larger than the hole?
December 6, 2021 at 9:28 am #480131menderman
Yes that is my question too.
I have done some more accurate measurements with my vernier gauge and the hole is 8.6mm. A 8.5mm drill fits nice but when I measure the drill I get 8.47mm.
The outer lens on the other oven neon is 10mmDecember 6, 2021 at 9:32 am #480132menderman
Thanks a lot for that – I have been searching ebay for ages and did not see that, maybe because i was adding oven to the search. But it does need to be high temp proof and that one says 120°. The one in the oven now says 150°
December 6, 2021 at 9:41 am #480133electrofix
Moderatorits fitted in a control panel and for safety it cant be that hot in case children touch it
December 15, 2021 at 11:17 am #480134menderman
ParticipantNew update on this. I wanted to buy from here but in the end went with a delonghi spares place as that said is for the oven. I brought a new lwns and a new neon. So that part is all fixed now. Just an observation that the new neon is not as bright as the old one but I can live with that.
Thanks all for your help -
