Re: replacement washer
Nomadpaul
When I say no new machine will rinse as well as my old one I mean it uses a lot more water to rinse eg. 1/3 up the door and it does 4. I will give you the challenge of naming a machine that puts water that high up the door that you could buy today 😆 .
Even with rinse plus the water will not go that high up the door, as most machines you cannot even see the water on the rinse cycle 😥 .
I have even had this backed up by a washer repair man with 30 years in the business. There is even a blog dedicated to this problem, there are countless people who have a problem with the rinsing of modern washing machines!
I’m not trying to offend here but washing machines do not rinse as well as they used to 🙁 .
HTH
Oliver.
