Replacing a Bosch Dishwasher SCE63M05GB/01 size 595 x 595 x 500 depth
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Replacing a Bosch Dishwasher SCE63M05GB/01 size 595 x 595 x 500 depth
  • #94921
    rocker
    Looking to replace this dishwasher, non available from Bosch…anyone know of any brands that may fit these sizes to replace….. cheers John
    #458769
    that model does not seem to exist
    rocker
    Sorry correct Enr SCE63M05GB/01
    #458771
    Edited OP. 😉
    #458772
    don
    Nothing like it at all I’m afraid not even in a dishdrawer. The nearest type would be the Bosch SKS62E22EU tabletop model.
    #458773
    you don’t say why you want to replace it
    is it beyond repair ?
    rocker
    Hi Dave ..I went to look at it the door won’t close unless its forced in…when door is in the closed position there is about an Inch gap between the door and the body…door not damaged not sure what has caused this or what parts may be required…
    #458775
    sounds like someone has put pressure on the door and bent the hinges. had a few do that going to another Bosch machine tomorrow to fit new hinges. On my machine hinges are only bent slightly. So you close the door and it pops open a bit and stops it. in your case I assume the door has to be forced the last inch to close it. If you look at the hinges you should see the metal flexing the door when it shouldn’t
    if so its really cheap
    rh hinge 00649098 £8.09
    lh hinge 00649095 £4.82
    rocker
    Cheers for your help & advice Dave.. will recommend to landlord…John
