Re: Replacing a Seal on a Siemens Freezer
The fact that a seal is even available, would suggest that it’s not rocket-science to replace it
IMO, first , source your new seal, then ascertain just how the old one comes out
some have a lip to clip it to the door and another to retain the door-liner
others have clips/screws/rivets holding the lineragainst the door with the seal-lip sandwiched between.
generally, if you roll the seal outward from the liner ,to expose it’s edge, you should see how it’s fitted.
In the worst case, you’ve already got a new seal, just use the “find an engineer” function here, to locate someone to do it!
