I’d like you to give me the advice on replacing an inlet hose for Zannussi 1250.
I discovered the leak from the connector of cold water hose (connecting the washer and the cold water pipe under the kitchen sink).
I tuned the stop cock (or valve with handle?) near the connector and the leak stopped, but I guess I’m not able to use the washer until I replace the inlet hose.
I found the spare hose on line, but I have no experience of installing the washer myself, and I am wondering if I can replace the hose by myself or I should ask a plumber to do it.
Please give me any advice on what I should do so that I can use the washer again ASAP!
Thank you for your help.
