Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Replacing bearings on AEG 1271 washer/dryer
- This topic has 3 replies, 2 voices, and was last updated 19 years, 2 months ago by
colint.
January 21, 2007 at 9:30 pm #24348
colint
ParticipantHi
I successfully replaced the bearings on a Zanussi FL1084 about 7 years ago, and it looks like they need replacing again 🙁
A friend has offered an AEG which needs it bearings done. I’m considering doing the AEG and getting rid of the Zanussi, as we could do with a combination washer/dryer (any thoughts on that?).I’ve had a look at the AEG, and it has a steel outer drum (the Zanussi has a plastic one). It also has the three-legged spider, which I don’t remember seeing on the Zanussi, but haven’t looked.
Questions:
Do I need to loosen the spider from the drum before hammering the drive shaft out?
Is it pretty easy to damage the steel outer drum while removing the shaft, it looks quite fragile?Thanks!
Colin
AEG LAVAMAT Prod No: 914676001 00
Type P6417650January 21, 2007 at 9:42 pm #201747Penguin45
ParticipantRe: Replacing bearings on AEG 1271 washer/dryer
Damn site easier than the Zanussi. Undo bolts and the cross piece pulls out backwards. Sharp tap with hammer on (protected) shaft usually frees it.
Ask spares@ukwhitegoods.co.uk for p/no ZN05108 – both bearings and oil seal in a kit.
Penguin45.January 29, 2007 at 10:58 am #201748colint
Thanks for the speedy reply!
Posting mainly for other’s benefit, as I’ve decided to abandon the AEG repair — the shaft looks pretty rusty, and I suspect there are too many parts needed to make it worth the effort.
I battled a bit, because the rim of the drum were bent over the ends of the three-legged cross piece, keeping it trapped even after I’d removed all the securing bolts. I wasn’t sure whether someone had done that in a previous repair, or whether they were supposed to be like that. Anyway, straightened them out, and the cross piece came out easily (but the rear face of the stainless steel drum has been pushed inwards — doesn’t look like that would be a problem if I pushed it back out again.)Thanks again for an excellent site (and parts service!)
Colin
February 3, 2007 at 10:10 pm #201749colint
colint wrote:I’ve decided to abandon the AEG repair.
Going to take the AEG to the tip, which seems a great pity, so much of it works fine. Is it worth removing any small expensive parts that may be of use to anyone else repairing a similar machine in the future?
