Sorry to be a ditz, I am trying to replace a door seal on a Bosch WFF 147S washer. I have taken off the metal ring holding the outer lip down but it seems the seal is fixed inside too at the rear of the seal. There seems to be a clip with a screw through it on the right hand side but I can’t get easy access to it or get a screwdriver under the screw to unscrew it
What do I do as I am not able to replace the door seal!!! Any ideas? It shouldn’t be this hard should it?? 😳
