Replacing/checking drain pump on Bosch SGS4012GB
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Replacing/checking drain pump on Bosch SGS4012GB
  • #9510
    Can anyone let me know the procedure for getting to the drain pump on the above model so I can replace it/check it – the dishwasher is not pumping out at all and even if I put the drain hose below the level of the sump, nothing comes out.
    thannks, Mike
    #134405
    Goatboy
    Re: Replacing/checking drain pump on Bosch SGS4012GB
    This is a very peril riddled procedure.
    Try this…..
    http://www.ukwhitegoods.co.uk/modules.p … whitegoods
    #134406
    Goatboy wrote:This is a very peril riddled procedure.
    You need to take the pump cover off (size T20 Torx headed single screw fix) to inspect the impellor as usually it can get blocked with bits of bone, crockery or broken glass.
    Details are included in your user manual on this procedure anyway. If you’re stuck, use the link Goatboy suggests 🙂
