replacing door hinge on servis m6513s Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › replacing door hinge on servis m6513s This topic has 4 replies, 4 voices, and was last updated 19 years, 2 months ago by bazza500. Viewing 5 posts - 1 through 5 (of 5 total) Author Posts February 7, 2007 at 10:50 am #24846 bazza500Participant Has anyone had to do this? The door hinge is rivetted on to the front panel with a wierd looking rivet part no.438003300. Does anyone have a part no. for the tool to do this? The machine is only 6 months old so i dont think the customer would be happy with a nut and bolt job. February 7, 2007 at 11:21 am #203520 A1TECParticipant Re: replacing door hinge on servis m6513s Hi,can’t see rivet on connect web site but a rivet is a rivet I recon any pop rivet of the same diameter should hold the hinge/door. February 9, 2007 at 8:10 am #203521 rockerParticipant Re: replacing door hinge on servis m6513s I did a hoover recently and came with rivets,( but not sure about servis) you only need a drill and rivet gun,takes 10 mins.(rivets cheap to buy) Cheers John February 9, 2007 at 9:18 am #203522 bazza500Participant Re: replacing door hinge on servis m6513s thanks for the replies but if i thought i could get away with normal rivets I would have it done by now. The rivets in question are countersunk perfectly into the front panel so as everything is nice and flush when its done. If anyone has the part no. for the tool to do this I`d be grateful. February 9, 2007 at 4:21 pm #203523 robbraParticipant Re: replacing door hinge on servis m6513s If GB Dars don’t supply the parts it’s a cabinet fault and BER but in all the years working on SUK machines I’ve never had a hinge come loose. Rob Author Posts Viewing 5 posts - 1 through 5 (of 5 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
